Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
The PROXXON AH 80 Surface Planer is the perfect companion to the DH 40 Thicknesser. Like the DH 40, this machine is also designed for precision stock machining. All load bearing components are made from CNC machined diecast alloy housed inside a nylon reinforced polyamide casing. The infeed/out-feed tables are also cast aluminium, ground to a fine finish. These give a working surface area of 400 x 80mm. The 2 x 82mm double sided HSS blades are fitted to a precision balanced block and rotate at 6,000 rpm to give a mirror like finish. The maximum depth of cut is 0.8mm, a clear calibrated indicator showing the setting from 0-0.8mm. There is an 55mm high alloy fence which almost covers the full length of the tables for maximum material support. This can also be tilted to 45°. The 35mm extractor outlet should be connected to a suitable vacuum extractor. Fully guarded for safety, plus a push stick is supplied.
