PROXXON Mesh Sanding Belts TB50 50 x 533 mm (3 Piece)
- Net structure for truly effective dust extraction
- Longer lasting,; net backing virtually eliminates clogging
- Universal product effective on a wide variety of materials
- Creates a finer scratch pattern resulting in a superior surface finish
Abranet Max is a tough aluminium oxide abrasive made by Mirka for the PROXXON TB 50 Table Belt Sander (SKU 109494). It has a high cut rate even on harder wood types and materials. The backing is a unique net structure that virtually eliminates clogging for a more efficient cut and faster stock removal. The abrasive process requires less pressure resulting in a more consistent surface finish.
Abranet Max gives high performance and has a longer lifespan than traditional abrasives, making it a cost effective solution. Designed for dry sanding by machine or by hand, its true dust-free sanding characteristics result in a cleaner work environment, as well as a better surface finish.
Dimensions: 50 x 533mm and comes as a pack of three. Available in grits; 100, 180 and 240.
Abrasive Belt Length | 533 mm |
Abrasive Belt Width | 50 mm |
