PROXXON PD 250/E Precision Lathe
507249
From £1,211.68 £1,009.73
  5. Half Star
7 Reviews
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Friday 13th Jun
  • Impressive 250mm between centres and 140mm swing
  • Automatic feed and thread cutting facilities
  • Electronic speed control; spindle range of 100rpm to 3000rpm
  1. PROXXON PD 250/E Precision Lathe
Total:
£2,034.92 £1,695.77
The PROXXON PD250/E has the capacity between centres of 250mm, and a swing of 140mm with an impressive 43mm over the slide. It has an automatic feed, thread cutting facilities, headstock chuck, live centre and top slide for taper turning. Equipped with an electronic speed control with a spindle range of 100rpm to 3000rpm, depending on belt ratio. The lathe chuck has a high quality 3-jaw chuck made to DIN 8386 Class 1 (concentricity tolerance 0.04mm). Capacity through reversing jaws is from 2-75mm. Included is a lathe chuck guard with safety shutdown. The lathe has a mounting plate for the PF230 mill/drill head to be fixed to it and a full range of accessories is available.
4.60 7
