PROXXON Universal Tool Bag 48pce
109509
From £139.98 £116.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Available to Order
Delivery
Free Standard Delivery*.
Delivery time is approximately 3 weeks.
  • Comprehensive and compact 48 piece general tool kit
  • Ideal for the workshop, home or car
  • Well organised inside a padded portable pouch
  • Each tool easily located and clearly marked
  • Outer dimensions: 335 x 295 x 60mm
An endlessly useful, compact 48 piece tool kit to keep in the workshop, home or car. Packed inside a padded portable tool pouch. Well organised, with every tool in its proper place inside the pouch, each tool is easily located, clearly marked and safely stored.
Outer dimensions: 335 x 295 x 60mm.
Contents:
VDE Insulated FLEX-DOT voltage tester screwdriver: 3mm tip
Water pump pliers: 250mm
Combination pliers: 180mm
FLEX-DOT screwdrivers: Slotted: 3mm & 5.5mm, Phillips: Ph1 & Ph2
Hex key set 1.5 to 10mm
Ball-peen hammer with graphite handle: 300g
1/4" drive Sockets: 4 to 14mm
25mm long 1/4" Hex bits: Phillips: Ph1 Ph2 & Ph3, Slotted: 4mm, 5.5mm & 6.5mm, Hex: 3mm, 4mm, 5mm & 6mm, Torx: TX8, TX10, TX15, TX20, TX25 & TX30
1/4" drive Standard ratchet
1/4" drive screwdriver handle
1/4" Hex Magnetic bit holder
Male 1/4" drive to male 1/4" Hex adaptor
Female 1/4" drive to female 1/4" Hex adaptor
1/4" drive extension
2m tape measure
SlimLine ring-combination spanners: 8mm, 10mm, 13mm & 17mm
