PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
23.9% APR (variable)
Purchase interest rate
23.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
The ROJEK range is available with a variety of additional options and accessories which can be customised, with some variations held in stock. Please contact our Business Team via the enquiry form, email sales@axminstertools.com or call 03332 406406. Our specialist consultants will be happy to guide you through the range and tailor the machine to particular needs and requirements.
This machine can also be viewed in person at our High Wycombe store.
The high standard of engineering and manufacturing make this spindle moulder one of the best in its class. It is well suited to small to medium sized professional joinery shops. The Industry 9 series machines are designed for hard, daily use. The FSN 550A is built with a precision ground cast iron table.
Even in its basic form the FS 550A comes with a tilting spindle, a choice of four speeds and a precise 1,200mm sliding table running on round CV 360T steel bars. The 30mm diameter spindle can be tilted and locked at any angle from -5° to +45°. The speed range allows different tooling to be used, from small blocks to larger panel fielding cutters up to 250mm diameter.
A wide range of optional accessories offer the opportunity to tailor the machine to particular needs as well as the potential to enhance the usefulness of the machine in the future.
Optional accessories include: - RH & LH Table Extensions, Cross Cutting Frame with Fence, Tenoning Table, Tenoning Hood, Ring Fence, Outrigger Roller, Electronic Spindle Height Adjustment, Modification for an Interchangeable Spindle, 30mm Extra Interchangeable Spindle and a 30mm Collet Chuck Interchangeable Spindle for router cutters.
The FS 550A is a high quality European made machine, built to last. Contact our Business Team to discuss your requirements; call 03332 406406 or email sales@axminstertools.com.
This product is classified as a Large Delivery
product and will normally be delivered within 14 working days.
This is a Bespoke Large Delivery service. Our team will contact
you upon completion of your order to discuss carrier options and arrange a
delivery date to suit you.
UK Mainland - £60
UK Remote & Offshore* - charge advised in basket
