Axminster Professional Engineer's Squares
- Four 90° angles, all faces square to all edges
- Stainless steel blade triple riveted for permanent accuracy
- Finely ground and with polished finish
- Conforms to DIN875/II, guaranteed square and straight
- Notch on inside corner aids accuracy of reading
- Blade measurements given are the inner length of the blade
- Supplied in a foam lined case
Axminster Workshop Double Edge Marking KnifeSpecial Price £20.38 £16.98 was £25.48 £21.23 Save £5.10 £4.25
An engineer's square gives you four 90° angles: internal, external, outside blade to inside stock and inside blade to outside stock. Compare this to a carpenter's try square which only guarantees accuracy on the internal angle. Our engineer's squares comprise a stainless steel blade, triple riveted into a steel stock. The hardened and tempered blade and the high quality steel stock are ground and polished for accuracy. Final polishing makes the rivets virtually invisible. Axminster Professional Engineer's squares conform to DIN875/II, guaranteed square and straight. The small notch on the inside corner of the square prevents accumulations of dust and dirt, small burrs or saw whiskers on the workpiece affecting the accuracy of the reading. Supplied in a foam lined case. N.B The blade measurements given are the inner length of the blade.
80mm inside edge, 100mm outside edge
130mm inside edge, 150mm outside edge
170mm inside edge, 205mm outside edge
225mm inside edge, 255mm outside edge
