Sedgwick Sliding Table for Saw Bench - 1,220mm
108143
From £906.68 £755.57
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Available to Order
Delivery
Contact us for a personalised quote.
  • Square and angled cuts up to 1,220mm wide
  • H/D extruded aluminium fence with telescopic arm
  • Fits both the TA315 and TA450 table saws
The Sedgwick TAXCT1220 sliding table fits both the TA315 and TA450 table saws. As the name suggests this enables you to crosscut panels up to 1,220mm wide. The table itself is a heavy gauge steel fabrication. It is supported on the right hand side by precision roller bearings running on a 40mm diameter solid steel bar. The left hand side is supported by a cast jib. Designed for cutting mitres and compound angles, end trimming, squaring, dividing and trimming. The table is fitted with a heavy duty extruded aluminium fence, which features a telescopic arm, a flip over repeat stop, and a quadrant scale.
