The Sedgwick TAXCT610 sliding table fits both the TA315 and TA450 table saws. As the name suggests this enables you to crosscut panels up to 610mm wide. The table itself is a heavy gauge steel fabrication. It is supported on the right hand side by precision roller bearings running on a 40mm diameter solid steel bar. The left hand side is supported by a cast jib. Designed for cutting mitres and compound angles, end trimming, squaring, dividing and trimming. The table is fitted with a heavy duty extruded aluminium fence, which features a telescopic arm, a flip over repeat stop, and a quadrant scale.
This product is classified as an Enquiry product. Enquiry
products require contact with our friendly Business Services team prior to
purchase to understand your requirements. Typically these products have many
customisation options or require product training.
Enquiry products are usually readily available and often despatched directly
from the manufacturer using the best delivery service available. Despatch
times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact customer services for more information.
