Shaper
  • Shaper Workstation Shaper Workstation
    £450.00
  • ShaperTape - 45m
    £19.00
  • Shaper Upcut Spiral Cutter 8mm Shank Shaper Upcut Spiral Cutter 8mm Shank
  • Shaper Engraving Cutter 8mm Shank
  • Shaper 1/8" Collet & Nut
  • Shaper Collet Kit in Micro Systainer Set of 5 Shaper Collet Kit in Micro Systainer Set of 5
  • Shaper Essential Bit Set in Micro Systainer Set of 3 Shaper Essential Bit Set in Micro Systainer Set of 3
  • Shaper Tapered Ball Nose Router Bit 11 Deg 1/4" shank Shaper Tapered Ball Nose Router Bit 11 Deg 1/4" shank
  • Shaper Up-Spiral Router Bit 6.3mm x 25.4mm 1/4" Shank Shaper Up-Spiral Router Bit 6.3mm x 25.4mm 1/4" Shank
  • Shaper Up-Spiral Ball Nose Router Bit 1/4" Shank Shaper Up-Spiral Ball Nose Router Bit 1/4" Shank
  • Shaper T-Slot Router Bit 5mm 8mm Shank Shaper T-Slot Router Bit 5mm 8mm Shank
  • Shaper Clearing Router Bit 16 x 16mm 8mm Shank Shaper Clearing Router Bit 16 x 16mm 8mm Shank
  • Shaper Up-Spiral O-flute Router Bit 3.175mm x 12.7mm 1/4" Shank Shaper Up-Spiral O-flute Router Bit 3.175mm x 12.7mm 1/4" Shank
  • Shaper Up-Spiral O-flute Router Bit 3.175mm x 6.35mm 1/4" Shank Shaper Up-Spiral O-flute Router Bit 3.175mm x 6.35mm 1/4" Shank
  • Shaper Up-Spiral Flat Router Bit 8mm x 35mm 8mm Shank Shaper Up-Spiral Flat Router Bit 8mm x 35mm 8mm Shank
  • Shaper Plate Universal Template for Shaper Origin Shaper Plate Universal Template for Shaper Origin
  • Shaper Origin Auto Pass Software
  • Shaper Upcut Spiral 6.3 x 38mm Router Bit 1/4" Shank Shaper Upcut Spiral 6.3 x 38mm Router Bit 1/4" Shank
  • Shaper 90 deg Engraving Router Bit 1/4 Shank Shaper 90 deg Engraving Router Bit 1/4 Shank
  • Shaper Up-Spiral O-flute Router Bit 5 x 20mm 8mm Shank Shaper Up-Spiral O-flute Router Bit 5 x 20mm 8mm Shank
Shaper – Precision Handheld CNC Routing
Shaper brings digital precision to woodworking with innovative handheld CNC routing technology. Combining the flexibility of a traditional router with the accuracy of computer-controlled cutting, the Shaper Origin makes complex woodworking projects easier, faster and more accessible. Designed and engineered by Shaper and assembled by Festool in Germany, the Shaper Origin handheld CNC router uses intelligent automatic cut correction to deliver exceptional accuracy. Ideal for creating intricate inlays, precise joinery, engraving, templates and custom designs, it allows woodworkers and professionals to work directly on their projects without the space requirements of a conventional CNC machine. Discover the Shaper range, including the Origin CNC router, Workstation, BenchPilot, Shaper Plate and specialist routing accessories, designed to expand your creative possibilities and bring precision to every project.
