Shokunin Japanese Retractable Pocket Saw - 80mm
- Compact saw with a fine Japanese saw blade
- 80mm blade retracts into the handle when not in use
- Handy pocket sized saw for trimming or modelling
- Cuts on the pull stroke tooth pitch 1.3mm(19.5tpi)
- Impulse hardened teeth for l;ong life
- Rustproof nickel plated blade
- For wood, plywood PVC pipe or bamboo
- Made in Japan
Shokunin Retractable Saw bladeFrom ÂŁ3.98 ÂŁ3.32
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price ÂŁ66.40 ÂŁ55.33 was ÂŁ89.98 ÂŁ74.98 Save ÂŁ23.58 ÂŁ19.65
What may appear at first glance to be an ordinary utility knife is actually a compact saw with a fine Japanese saw blade. This really is an ultra handy saw, whether you’re a model maker or occasionally need a saw for fine trimming. The 80mm blade fully retracts into the handle when not in use. Once retracted, it is protected from damage and allows you to carry the saw in a tool bag or pocket, or store it in a drawer.
The blade is 80mm long with a tooth pitch of 1.3mm(19.5tpi). The teeth are impulse hardened and the blade given a rustproof nickel plating. It cuts quickly on the pull stroke in wood, plywood, PVC pipe or bamboo.
Made in Japan.
Blade Thickness | 0.45 mm |
EAN Barcode | 4903524011605 |
Kerf | 0.55 mm |
Length of Blade | 80 mm |
Overall Length | 235 mm |
Saw Blade Type | Crosscut |
Tooth Pitch \ tpi | 1.30 mm \ 19.5 tpi |
- Standard Delivery* - £1.99
