Trend Yeti CNC Precision Pro Plus Smartbench with V Carve 230V
110633
From £9,258.00 £7,715.00
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Available to Order
Delivery
Contact us for a personalised quote.
  • IMPORTANT: Please contact Axminster Tools to arrange a more detailed explanation of the Trend Smartbench and the options available to suit your individual needs. Please call 03332 406 406 to speak with the Axminster Business Services team to arrange the consultation, or fill in the enquiry form further down the page. Please note: this machine is delivered directly from the manufacturer.
  • Highly accurate CNC routing for the workshop or on site
  • VCarve Pro software included
  • Yeti Pilot for automated adaptive cutting feeds
  • SC2 Spindle, for intuitive communication for monitoring spindle loads.
  • Job Recovery, allows you to restart the job from the point it was interrupted or cancelled
  • Easy to use; intuitive touch screen control
  • Easily to transport and set up; fits in a van
  • Large capacity; max area 2,500mm x 1,250mm (8' x 4')
  • Portable; sections made to be handled by one person
  • Perfect for furniture making, cabinetry, panelling, interior design, boat building, caravan fitting, camper fitting, car restoration, sign making, carving, and much more
  • Show More
Important: If you would like further detailed information or a demonstration on the CNC Precision Pro Plus SmartBench, simply fill in the attached enquiry form and one of our sales team will be in contact to discuss your requirements. This machine is delivered directly from the manufacturer.
Supplied with Trend Yeti CNC Precision Pro Plus Smartbench and VCarve Software
SmartBench finally brings CNC routing capability into your workshop or on site. Perfect for Furniture Making, cabinetry, panelling, interior design, boat building, caravan fitting, camper fitting, car restoration, sign making, carving, and much more - SmartBench allows new levels of creativity, accuracy and time-saving as well as efficient use of materials.
SmartBench Pro Plus works on material sizes up to 2,500mm by 1,250mm (8’ x 4’) with an impressive cutting depth up to 152mm (6”) – meaning the machine is equally at home drilling, cutting shapes, machining components, or even making intricate carvings.
It is perfect for a wide variety of materials, including wood, plywood, MDF, Corian, Acrylic, aluminium and many more. The revolutionary design gives a high degree of accuracy over the entire work surface. Operation could not be simpler. The touchscreen control unit can receive jobs or cutting instructions via wi-fi or USB.
SmartBench uses nc or gcode files and can be supplied with highly intuitive software which can be used on a Mac or PC.
The Precision Pro Plus offers these additional features to the Precision pro
Yeti Pilot is the world first automated adaptive cutting feeds, which works together with the SC2 Spindle, for intuitive communication where it constantly monitors spindle loads. Job Recovery, allows you to restart the job from the point it was interrupted or cancelled.
SmartBench fits into a van for transport to site, where it can be set up and ready to go in just a few minutes. Where workshop space is at a premium, it is easy to store when not in use. The unit disassembles in seven easily transported parts -making it easy for one person to handle.
Trend CNC VCarve Pro software
The VCarve Pro is an impressive and intuitive software solution for use with a CNC router and the perfect addition to the Precision Pro SmartBench. The VCarve Pro software includes a full set of drawing and editing tools for 2D design and the calculation of 2D and 2.5D toolpaths. It can import and create toolpaths for 2D designs and for a single 3D design (STL, OBJ, SKP etc).
The Pro version allows true shape nesting, toolpath templates to automate and reuse toolpath strategies working on components larger than 600 X 600 mm.
Warranty 1 Year Warranty
