UJK Rail Clamp MFT Top
109796
From £279.98 £233.32
3 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Friday 18th Jul
  • UK Made, Precision-engineered Rail Clamp MFT Top
  • MFT accuracy with innovative T-Slot design for versatile clamping
  • Position clamps anywhere along the track and lock them with one hand
  • T-Slots ensure compatibility with a range of clamps designed for track saws
  • Top is a snug drop-in fit in the UJK MultiFunction workbench frame or the Festool MFT table.
  • CNC machined tracks accommodate a wide range of clamps
  • Chamfered holes ensure tight tolerances and precise assembly
  • Made from durable birch ply for strength
  • Size 1,102 X 718mm
  1. UJK Rail Clamp MFT Top
Total:
£434.94 £362.45
The UJK Rail Clamp MFT Top will advance your busy workshop with more convenience, added precision to our woodworking projects, and unmatched versatility.
Proudly made in the UK, the UJK Rail Clamp MFT Top seamlessly combines the accuracy of an MFT top with innovative T-Slots, increasing your clamping capabilities.
Unlock the freedom to position your clamps anywhere along the track, securing them effortlessly with just one hand while you can continue to work with the other. Unlike standard MFT tops with fixed intervals – our bench top allows you to tailor your clamps for each project. The inclusion of T-Slots ensures compatibility with a range of clamps designed for track saws and perfectly fits the Festool MFT table. Slide your clamps into the CNC machined track with unparalleled ease as you position and lock them securely into place for a seamless workflow.
The UJK Rail Clamp MFT Top is engineered with chamfered holes as standard for added precision, a hallmark of UJK workbenches. This design element ensures tight tolerances, delivering square and firm assembly with every use. Crafted from high-quality birch ply, this bench top is not only robust but also showcases the exceptional craftsmanship synonymous with UK manufacturing.
Overall Size:1,102 X 718mm
Note: Sag of the table can happen, to avoid this, screw two batons across the width to ensure the table is flat.
British Made British Made
5.00 3
