Earn extra with DOUBLE Points on all purchases!
Festool MFT KAPEX Multifunction Table
- Ideal bench for compound mitre saws KAPEX KS 88 or KS 120
- Bench height of 790mm ensures comfortable working
- 815mm by 525mm workspace
- Perforated top easy to integrate with Festool clamping systems
- Folding legs and 19kg weight for easy transport
At 790mm high with the legs extended, the MFT/KAPEX table offers you the perfect working height and size for use with either the Festool KAPEX KS 88 or KS 120 mitre saws. The perforated MDF top offers two major benefits. The feet of the Festool KAPEX mitre saws drop directly into specific holes. This puts the saw in the correct position on the work top and prevents the saw moving when in use. Remove the saw and the multi-hole work surface becomes a versatile workstation. Use Festool clamps to secure a workpiece for routing, sanding or sawing. The table will work with a large assortment of Festool clamps and clamping accessories. The worktop measures 815mm by 525mm. Slip-resistant feet prevent the table drifting in use. One foot is adjustable to accommodate uneven surfaces. With its folding legs and weighing 19kg, you can easily move it around the workshop or transport it to and from job sites. It is robust, durable and made for quality materials for a long service life. Folded dimensions are 869 x 581 x 180mm, load capacity 120kg.
