UJK Straight Router Cutters 12mm Shank
From £17.23 £14.36 was £22.98 £19.15 Save £5.75 £4.79
1 Review
  • British made UJK Router Cutter
  • Xylan coated minimising friction and resin build-up and enhances chip flow
  • Manufactured from EN8 Steel for strength
  • Innovative ‘Stop Insertion Ring’ replacing a K line
  • Stop Insertion Ring as a rubber collet seal, preventing dust entering the collet slots
  • Extended shank length for use with router jigs and tables
  • High-grade micro carbide ground tip for superior plunging performance
  • Straight cut router cutter ideal for various materials
  • Straight cut router cutter is a great all-rounder
Router Cutters: UPGRADED
Experience the next level of routing with UJK's latest innovation in router cutter technology.
Our British made UJK Router Cutters are designed with the modern workshop in mind, delivering unparalleled performance and durability. See the full range
Enhanced performance coating
The Xylan coating minimises friction, prevents buildup, and enhances wear resistance. This special coating ensures smoother cuts and a longer lifespan for your cutter.
Superior plunging
The high-grade micro carbide ground tip ensures superior plunging performance. Achieve clean, precise cuts every time with a cutter that stays sharper for longer.
Simplified setup
UJK Router Cutters come with a revolutionary 'stop insertion ring', making setup a breeze. Say goodbye to the hassle of searching for faded K lines. This innovative feature also doubles as a rubber collet seal, preventing dust buildup and extending the life of your cutter.
Durability meets resilience
Crafted from EN8 steel, UJK Router Cutters are built to last. The robust construction ensures durability and resilience, providing a stronger, tougher cutter that can withstand the demands of any project.
Extended reach for modern workshops
UJK Router Cutters feature an enhanced shank length, providing the extended reach needed for modern routing tasks. Whether you're working with intricate jigs or large workpieces, UJK Router Cutters are up to the challenge.
British Made
Experts at UJK have designed, developed and manufactured, in Britain, an advanced router cutter to meet the demands of the modern woodworker, for safer, long lasting router cutters.
Router cutters like you haven’t experienced before. The UJK Router Cutters are built with the traditions of woodworking in mind, with innovative solutions for the modern woodworker.  The new features ensure your routing is safer, cleaner, and lasts longer.
Designed, developed and manufactured in Britain, its robust construction is crafted from EN8 steel, ensuring durability and resilience for a strong router cutter. The Xylan coating enhances performance by minimising friction, reducing resin buildup and aiding chip flow, therefore reducing heat. Creating a safer routing environment and enhancing wear resistance, adding longevity to the cutter. Whether you’re a seasoned professional or a hobbyist, these cutters will withstand the test of time.
The inclusion of a 'stop insertion ring' eliminates the need to search for faded K lines, ensuring the safe & correct cutter insertion every time, as well as saving valuable time during fitting. Plus, it also acts as a rubber collet seal to prevent wood dust from entering the collet slots.
The enhanced shank length offers extended reach for contemporary workshops equipped with router jigs and tables. A high-grade micro carbide ground tip allows for superior plunging performance – all cutting tips on this are micrograin carbide, giving longevity to the cutting performance.
The UJK straight cut router cutter is a great all-rounder. Create grooves, channels, cut rebates, and make straight cuts. It’s equally useful for trimming and planning applications, with compatibility across various materials: man-made boards, plywood, chipboard, faced materials, natural timbers, hardwood, and softwood and kitchen worktops.
Proudly made in Britain, the UJK Router Cutters embody quality and precision.
British Made British Made
5.00 1
