Axminster Workshop AW82E Dust Extractor - 230V
107696
From £229.98 £191.65
  5. Half Star
76 Reviews
In Stock - Ready to dispatch
  • Compact wood chip extractor for small workshop use
  • Fitted with castors for easy mobility
  • Supplied 30 micron filter bag
  • Airflow: measured our workshop 1,050m³/hr @100mm
The AW82E is a compact, mobile chip extractor for use around a small workshop. It is powered by a 230V 1.1kW induction motor, which produces quite a substantial airflow. The better than average performance makes it perfect for chip extraction from bandsaws, table saws, spindle moulders, planers or thicknessers.
The main body can be mounted either way up, giving you a choice of inlet positions on the top or bottom of the machine. The base has castors fitted for easy mobility around the workshop. The AW82E comes with a 30 micron filter bag along with a plastic waste sack. The inlet size is 100mm, allowing easy connection to many types of machines using flexible hose (not supplied). This machine is reasonably quiet in operation, compact in size, and suits many woodworking machines usually found in a smaller workshop.
Airflow: as measured in the Axminster workshop 1,050m³/hr @100mm.
Note stepping down the hose diameter below 75mm, is not advisable as the airflow volume will drastically fall.
The filtration can be upgraded with an optional 1 micron cartridge filter. This has a very large surface area, so does not impede the airflow.
Warranty Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
4.40 76
