Bosch GTS 635-216 216mm Table Saw With Leg Stand - PACKAGE DEAL
720727
720727
From £539.98 £449.98
12 Reviews
Low Stock - Ready to dispatch
  • Bosch GTS 635-216 216mm Table Saw
  • 1,600W compact saw with big capacities
  • 70mm max depth of cut, 635mm max width of cut
  • Highly portable, weight 22kg
  • Fence locks front and rear for precise, parallel cuts
  • Safety switch with emergency stop
  • All the accessories can be stored onboard
  • Supplied with TCT blade, mitre fence and push stick
  • Bosch GTA560 Table Saw Stand
  • Foldable, lightweight stand for the Bosch GTS 635-216 saw
  • Opens out to form a strong and stable base
  • Comfortable working height
  • Folds flat for easy transportation
  • Front and rear catches lock saw securely in place
  • Show More
Package deal comprises a Bosch GTS 635-216 216mm Table Saw and a Bosch GTA560 Table Saw stand.
The Bosch GTS 635-216 table saw is a compact saw with large cutting capacities. The redesign of the motor / gearbox configuration maximises the cutting height from the 216mm blade. The result is a highly portable saw bench with a maximum depth of cut of 70mm and a cutting width of up to 635mm.
The extruded aluminium rip fence locks front and rear for precise, parallel rip cuts every time. Removing the face of the fence, laying it flat and re-attaching it forms a low fence for safe cutting of thin workpieces. The 1,600W motor provides all the power required to handle 70mm at full capacity.
Safety is paramount; the GTS 635-216 features a soft start, restart protection, a safety switch with emergency stop and efficient dust collection (when connected to a suitable vacuum extractor).
The machine is easy to transport with its ergonomic handles and low weight of 22kg. All the accessories can be stored on the machine; a place for everything and everything in its place, nothing gets lost. Its compact size makes it a good choice where space is limited, as it will fit neatly under a bench when not in use. For site work, a stand is available turning it into a useful saw bench with great capacities.
Supplied with TCT blade, mitre fence and push stick.
This foldable, lightweight stand forms a strong and stable base for the Bosch GTS 635-216. This is a particularly useful accessory, offering a comfortable working height when in use and easy transportation when done. Front and rear catches lock the GTS 635-216 securely in place.
Warranty Bosch Professional 3 Year Warranty (Registration Required)
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
Registration required within four weeks of purchase. More information can be found on the Bosch warranty website and in the warranty conditions.
4.80 12
