Bosch T101BIF Jigsaw Blades Special Laminate (Pkt 5)
610812
610812
- Especially designed for cutting wood laminates
- Clean precise cutting on both sides of the laminate
- Pack of 5
Show more
Show less
5 - 15mm, wood laminates, clean precise cutting on both sides of the laminate.
Blade Type | Bi-metal, Ground and Taper Ground |
Jigsaw Blade Length | 82 mm |
Jigsaw Blade Type | Clean Cuts |
Max Cutting Depth | 15 mm |
Pack Quantity | 5 |
Tooth Pitch \ tpi | 1.70 mm \ 15 tpi |
#AxminsterTools
