Veritas Miniature Rip Tenon Saw
- Fully functional 1/3 scale Veritas Rip Tenon Saw
- Overall length of only mm
- High-carbon Steel blade
- Walnut grip handle
- Cut straight and accurate lines in wood
- Ideal for tenons, dovetails, miters, grooves, and slots
Create beautiful and sturdy joints for your miniature furniture, cabinets, frames, boxes, and other woodworking projects.
This miniature tool is a fully functional 1/3 scale version of a Veritas saw, measuring just 178mm (7") in overall length. As with its full-size version, it has a moulded spine for good balance between cutting action and surface finish. The closed walnut handle is designed to give good power transfer whilst allowing accurate control.
The high carbon steel blade is 140mm (5.1/2") long and provides an effective cutting depth of 32mm (1.1/4"). The 27 tpi rip cut teeth have a 14° rake using the typical 60° included angle.
Whether you're a beginner or expert worker the Veritas miniature range are all beautifully crafted precision tools, making them popular with small-scale woodworkers and tool collectors alike.
Made in Canada
EAN Barcode | 722356027851 |
Overall Length | 178mm |
Saw Blade Type | Rip Cut |
- Standard Delivery* - £4
