Vitrex Torque Master Power Tile Cutter 450W 230V
- Water cooled, dust free tile cutting
- 110mm diamond blade up to 25mm depth of cut
- Cuts ceramic and porcelain wall and floor tiles
- Continuous rim blade for an extra clean cut
- Double extension tables for larger format tiles
- 450W Hi-Torque geared motor
- Splash guard with variable height adjustment
- Fully adjustable mitre guide
- Flip-up cutting table for 22.5° & 45° edge mitres
- "No Mess" water recirculation system
- Quick-release splash guard for plunge cuts
- Show More
The Vitrex Torque Master Power Tile Cutter is capable of cutting ceramic and porcelain, wall and floor tiles. The continuous rim diamond cutting blade ensures a clean cut. Its 450W Hi-Torque geared motor gives maximum cutting performance. The blade is water cooled for dust free cutting and fitted with an adjustable height splash guard. The splash guard has a quick release for plunge cuts. The water is continuously recirculated keeping the blade cool throughout the cut. A straight fence is provided along with an adjustable mitre fence for angle cuts from 0° to 45°. The generous sized top provides plenty of support for large floor tiles. The right hand top section flips up for cutting 22.5° and 45° mitres along the tile’s edge.
Blade Diameter | 110 mm |
Bore Size | 22 mm |
EAN Barcode | 5011204603749 |
Max Depth of Cut @ 45º | 17 mm |
Max Depth of Cut @ 90º | 25 mm |
Model | 10 3402 NDE |
Nett Weight | 6 Kg |
Overall L x W x H | 375 mm x 365 mm x 180 mm |
Power | 450 W |
Rating | Home Workshop |
Table Size | 375 mm x 365 mm |
This product is classified as a Make to Order product.
- Standard Delivery* - Free
