Gold zinc plated steel finish screws with high resistance to corrosion. Suitable for interior use in soft or hard wood, chipboard, OSB or MDF.
The head
Increasing the size of the head where it meets the body makes these screws much stronger. This minimises the risk of the head shearing under the final tightening torque.
The tip
The tip cuts as it penetrates and the initial portion of the thread engages immediately. The sharp point helps when placing the screw and prevents skating.
A4 (also known as Marine Grade) stainless steel contains a small amount of molybdenum, which creates a particular type of steel having a much higher resistance to surface corrosion when compared with standard A2 stainless steel. The screws have a Torx head ensuring the virtual elimination of 'cam out', where the screwdriver is liable to slip under pressure, damaging both the screw head and the bit. Screw threads are also wax lubricated for almost effortless driving into most timbers. These screws are suitable for all outdoor projects such as garden furniture, timber framing, sheds as well as boat building and renovation. Boxes of 200. Except 5 x 60mm wood screws which are boxes of 100.
