Arbortech Turbo Scraper
110874
From £125.00 £104.17
1 Review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 17th Jun
  • Rapid freehand wood scraping
  • Ultra-smooth, scratch-free finish
  • Cuts at a negative angle to prevent digging into wood
  • Distinctive design provides real-time visibility while carving
  • Durable carbide teeth ensuring long blade life even in hardwoods
Empower your finish
Unlock precision and finesse in your carving with the Arbortech TURBO Scraper â„¢. This innovative tool gently scrapes away wood, leaving a smooth scratch-free finish.
Turbocharged performance
A high-performance upgrade to the traditional hand scraper, allowing precise carving through pressure adjustment alone. Ideal for shaping internal and external profiles with speed and accuracy. Unlike traditional burr discs it remains unclogged, ensuring impeccable accuracy.
Cutting edge design
Unique design enables real-time visibility while carving, providing precise monitoring of carving progress. Engineered for negative-angle cutting, it minimises tear-out and chipping, resulting in a smooth, scratch-free finish.
Exceptional control
The TURBO Scraper â„¢ is slower at removing timber compared to the TURBO Plane and Industrial Woodcarver. This intentional design feature gives professionals superior control over delicate tasks making it ideal for high-end craftsmen, such as furniture and instrument makers.
Carve with confidence
This beginner-friendly attachment is less aggressive than other tools, making it more forgiving to use. With a lack of kick or grab it is easy to control and mistakes, such as burn marks, are effortlessly removed.
Versatility
Perfect for big wide curves, chair seats, spoon carving and much more. Compatible with the Arbortech Power Carving Unitâ„¢ or any standard 100mm (4") or 115mm (4 1/2") grinder.
  1. Arbortech Turbo Scraper
Total:
£349.00 £290.83
The Arbortech TURBO Scraperâ„¢ is the ideal choice for woodworking projects that demand precision and accuracy
Think of this powerful disc as a turbocharged upgrade to a conventional hand scraper. Specifically engineered to cut at a negative angle, it minimises tear-out and chipping. When applied with pressure, it gently scrapes wood, resulting in a smooth, scratch-free finish. Its distinctive design allows you to see your work clearly, meaning you can monitor carving progress and achieve exceptional precision - even on delicate details. Unlike traditional burr discs, the TURBO Scraperâ„¢ remains unclogged, ensuring impeccable accuracy. Cleaning becomes effortless, eliminating the need for an array of tools.
The TURBO Scraper is slower at removing timber compared to the TURBO Plane and Industrial Woodcarver. This intentional design feature provides professionals with superior control over delicate tasks but also makes it by far the most beginner-friendly. By merely adjusting the pressure you carve as much or as little as you like and, should you get any, burn marks are quickly and easily removed. The profile is perfect for doing big wide curves, ideal for chair seats and is great for spoon makers when used in a vertical position. Those looking to shape internal and external profiles with speed and accuracy, such as high-end furniture and instrument makers, will also find this blade hugely beneficial.
The disc is made from forged aluminium which offers a high strength-to-weight ratio and durability. The three durable tungsten carbide blades hold their edge well and can be rotated and replaced for optimum performance and longevity. Compatible with the Power Carving Unitâ„¢ or any standard 100mm (4") or 115mm (4 1/2") grinder. When using the TURBO Scraper, ensure your angle grinder has an auxiliary handle for better balance, control, and visibility during carving.
Craftsmanship meets ease with the TURBO Scraperâ„¢!
5.00 1
