Artisan Twist Pen Kits
- 10kt gold (Artisan logo) or 24kt gold (Black clip)
- Chrome version available with Artisan logo or black clip
- Solid brass, break resistant clip
- Tungsten carbide tipped
- Epoxy coating on 24kt version gives additional protection
Our most popular pen kits, and the reason for this is that they are good quality, reliable and when completed, make wonderful presents. The 10kt Twist Pen requires only half a turn to advance the mechanism, at the same time locking the mechanism in place so that the refill will not retract during use. A heavy, solid brass break resistant clip, plated with 10kt gold plate makes the pen more attractive. Each pen kit includes a tungsten carbide tipped refill to provide smooth, trouble-free writing. The 24kt Twist Pen is gold plated with a black clip and epoxy coated to give some additional protection to the plating. Requires 7mm drill. Use refill 310492. These pens can be turned using the bushes supplied as standard bushes with the Axminster Pen Mandrels.
Bushing Set Order No. | 8.5mm O/D (as supplied with mandrel) (100793) |
Difficulty | Beginner |
Drill Bit Required | 7 mm |
Minimum Blank Size | 16 mm x 16 mm x 112 mm |
Pen Type | Twist Pen |
Refill Order Number | 310492 |
