Axcaliber Contract 205mm TCT Saw Blades
AX826765
AX826765
- Generously sized tips brazed onto tensioned quality steel plates
- Rip (24 teeth)
- General Purpose (32 teeth)
- Cross Cut (48 Teeth)
- Extra Fine (64 teeth)
- 2.2mm Kerf, 1.6mm plate
Show more
Show less
The Axcaliber range of Contract TCT (Tungsten Carbide Tipped) circular saw blades offers an unmatched blend of choice, cutting performance and price.
Manufactured in one of the most advanced facilities in the world, they are produced to the highest standards using the finest materials available. With the range covering everything from hand held power tools right up to large panel saws used in production workshops, you will be certain to find
a blade to suit every requirement. Bore size being 30mm or 5/8" as indicated.
Blade Diameter | 205 mm |
Kerf | 2.2 mm |
Maximum RPM | 8,500 rpm |
Plate Thickness | 1.5 mm |
Tooth Format | ATB |
