Axcaliber Edge Breaker Router Cutter Set 4
105925
Special Price £45.00 £37.50 was £71.98 £59.98 Save £26.98 £22.48
11 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Tuesday 20th May
  • Exact and controlled rounding over
  • Perfect arris removal
  • Set of 4: 1, 1.5, 2 and 2.5mm radii
  • Bearing guided for straight or curved edges
  • Minute relief prevents corners digging in
  • Essential prior to applying paint or varnish
  • All 1/4" shank
  1. Axcaliber Edge Breaker Router Cutter Set 4
Total:
£90.84 £75.70
Woodworkers traditionally round over a corner or create a slight chamfer on an edge, ‘removing the arris’ as it is known. There are several reasons for this. A sharp corner is uncomfortable to handle. Depending on the species, the wood may splinter or crumble. A sharp corner will not take the finish. You cannot paint a sharp edge. Try putting a coat of light paint over dark wood, once dry a dark unpainted line on the edge is obvious.
The Edge Breaker set rounds over sharp edges for a very exact and controlled result. There are 4 radii: 1mm, 1.5mm, 2mm and 2.5mm, all bearing guided for rounding straight or curved edges. Importantly, the radius of each cutter rather ending with a 90° corner has a slight relief angle to ensure a perfect finish. Even a 1mm radius makes a world of difference, whatever finish you apply.
All cutters are 1/4" shank.
4.90 11
