Axcaliber Kitchen Worktop Cutter
From £16.28 £13.57
  5. Half Star
2 Reviews
  • Great value TCT worktop cutter, 51mm depth of cut
  • For use with kitchen worktop jig and 1/2" router
  • Clean finish in laminate and solid wood worktops
A great value cutter for a one off job or those times when it may not be a good idea to use your best high quality expensive cutter. This 1/2" TCT router cutter will cut solid wood and laminate kitchen worktops, leaving a clean finish for a close fitting joint, when used with a worktop jig and 1/2" router. Twin flutes ensure smooth and efficient cutting. With a cutting depth of 51mm it is ideal for general worktop cuts.
N.B. The cutter does not have a bottom cut.
4.50 2
