Axcaliber Premium 216mm TCT Saw Blades
From £24.88 £20.73
22 Reviews
  • Micro-grain TCT tips brazed onto tensioned steel plates
  • Resin dampened for effective noise reduction
  • ATB tooth format for clean, fast cut
  • High quality surface finish
  • General Purpose (24 teeth)
  • Cross Cut (48 Teeth)
  • Extra Fine (56 teeth)
These blades are particularly suited for use with table and mitre saws. They offer high performance and high quality of surface finish.
Axcaliber Premium circular saw blades are from the world's largest blade manufacturer. Using the latest production techniques and the best materials, the Premium blades feature micro grain TCT tips and resin dampened laser cut plates, which substantially reduce noise whilst cutting. The "Premium" range is the blade of choice for all joinery and cabinet workshops demanding the very best performance.
The fine crosscut blades feature Alternate Top Bevel (ATB) ground teeth, ensuring a clean, fast cut. The tops of the teeth are bevelled alternately at approximately 15°. This tooth configuration bears a sharp pointed tip that provides a neat clipping action for very fine finishes. Two teeth will span the entire width of the kerf. It produces very low cutting pressures that almost eliminate the tendency to tear out. The chips fall free in the chip spaces created by the large side clearance angles.
4.90 22
