Axcaliber M42 Premium Bandsaw Blades
From £32.98 £27.48 was £32.98 £27.48 Save £0.00 £0.00
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Buy two Axcaliber Bandsaw Blades, get cheapest blade free! Add two or more to your basket and use code: AXBB25
  • M42 high speed steel with 8% Cobalt welded to high strength spring steel alloy backing
  • High resistance to heat, abrasion, and vibration
  • Variable pitch teeth for a wider range of applications
  • Reduced sawing harmonics for quieter, reduced vibration cutting
  • Long life span of the blade
  • Cost per cut ratio is lower due to the much increased life and resistance to damage or fatigue
Get the best blade for your task
Premium saw blades use M42 high-speed steel with 8% Cobalt which has been welded to a spring steel alloy backing. This results in a material that has a far greater resistance to heat and abrasion, allowing improved cutting performance in those materials that might have proved troublesome with a 'standard' blade. Many types of material can be cut with ease, all metals including hard steels when the blade is fitted to a slow running metal cutting bandsaw, or all timbers including abrasive timbers such as teak as well as man-made boards like mdf and chipboard when using a higher blade speed on a wood cutting bandsaw. M42 blades are so resilient that reclaimed timber presents no difficulties, as the blade will slice easily through the odd nail buried under the surface. N.B. Due to the possibility of stress fracture we do not recommend the use of these blades on wood cutting bandsaws with a wheel diameter of less than 12” (305mm). Blades are available in 1/2" x 6-10tpi & 10-14tpi, 3/4" x 4-6tpi & 10-14tpi.
British Made British Made
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsDelivery QuickA clock faceCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPreviewAn eye symbolPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStarA Star symbolStarA Star symbolStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
