Axminster Professional 254mm TCT Planer Knives
- Ideal for abrasive or hard timbers
- Use with glued panels
- Resharpenable with Silicon Carbide "Green" wheels
- Economically priced
- Set of 3
These TCT Planer knives are ideal for machining abrasive exotic timbers or for those regularly preparing hardwoods. Also should be used when machining glued panels. Economically priced and in packs of 3, will fit the Axminster AW106PT2/AH106PT planer thicknessers or similar machines from other brands. Not as sharp as HSS but holds an edge for far longer. 254 x 30 x 3mm. Resharpenable using a Silicon Carbide "Green" grinding wheel.
EAN Barcode | 5052511007707 |
Knives | TCT |
Number of Knives | 3 |
Overall L x W x H | 254 mm x 30 mm x 3 mm |
To Fit | Axminster AW106PT2, Axminster AH106PT |
- Standard Delivery* - Free
