This smaller guide assembly provides ball bearing supports at the rear and on the sides of the blade in place of the more usual rubbing blocks. The improved support will reduce blade vibration and give a cleaner and more accurate cut. For and aft movement of both rear and side bearings is controlled by screws and the bearings themselves are mounted on eccentric bosses for precise setting of the blade clearance. Supplied as a complete set of upper and lower assemblies complete with bearings. When fitting these guides to your machine some modification may be needed. The top guide will mount onto a 12mm round bar. Perfect for upgrading smaller bandsaws.
Provides ball bearing supports at rear and sides of blade
Improved support reduces blade vibration
Gives cleaner, more accurate cut
Complete set of upper and lower assemblies with bearings
