Axminster Workshop Table Insert for AW254TS Table Saw
106807
From £20.68 £17.23
  4. Half Star
9 Reviews
Dispatching Soon
- Email me when available
Delivery
£1.99 Standard Delivery*. Free delivery over £30.
Dispatch estimate is within 7 weeks.
  • Alloy table insert with minimal blade clearance
  • Gives greater material support when cutting thin strips
  • Helps prevent end grain tearout when crosscutting
  • Used when the cutting blade is vertical only
  • Replaces the standard table insert
  1. Axminster Workshop Table Insert for AW254TS Table Saw
Total:
£141.22 £117.68
This optional alloy table insert for the Axminster AW254TS table saw, has an exceptionally narrow slot for the saw blade. Designed for use with the saw blade in the vertical position only, it offers vital support when cutting thin strips, preventing material dropping down past the blade and into the machine. In addition, it helps when crosscutting.
The slot is just wide enough for the blade kerf. When fitting for the first time it may be worth setting the blade at its lowest position, fitting the insert, switching the saw on then raising the blade very slowly to its full height. Being alloy, if it catches the blade slightly there will be no damage to the blade.
3.70 9
