PayPal Credit is like a credit card without the plastic. And with 0% interest for 4 months on all purchases of £99 or more, it’s the perfect way to spread the cost of larger online purchases.*
Representative Example:
Representative
21.9% APR (variable)
Purchase interest rate
21.9% p.a. (variable)
Assumed Credit limit
£1,200
This example above illustrates the typical cost of using PayPal Credit as a standard funding method. If you take advantage of our offers and promotions, including our 0% for 4 months offer, the interest rate that applies will be lower in many circumstances.
How 0% interest for 4 months works
Spend £99 or more in one go with PayPal Credit.
Then automatically get 0% interest for 4 months on that purchase.*
Even better, you can use this offer again and again on every purchase over £99.
This Professional benchtop bandsaw is made to exacting standards to meet the requirements of a busy workshop with limited available space.
Designed by Axminster Tools
Our in-house designers have designed a fantastic bandsaw to meet the high standards required for the professional user.
Small and compact
This professional bandsaw is packed with many features found on bigger machines, meaning you get more for your money with Axminster Tools.
Generous depth of cut
Delivering 160mm depth of cut and 250mm width, this bandsaw is able to manage the most demanding of tasks.
Rack & Pinion Adjustments
The rack & pinion adjustment on the table tilt and upper blade guide height makes it quick and easy when setting up. uper smooth starting, acceleration and deceleration which is all powered by a 1.5kW (2HP) motor.
High quality cast iron table
The fine finish, heavy duty cast iron table aids to reduce vibration and allows smooth travel of the workpiece.
Rip fence with fine adjustment
The heavy duty rip fence with fine adjustment aids to quick and easy set up.
Ball bearing blade guide with micro adjustment
This helpful feature enables you to quickly and easily get set up, meaning there’s less downtime.
Dynamically balanced cast iron wheels
The high quality wheels aid towards low vibration while you work.
750w motor
The powerful motors means you are able to deliver ample power for the biggest cuts.
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
This benchtop bandsaw is made to exacting standards to meet the requirements of a busy workshop with limited available space. Designed in house, we set out to create a bandsaw incorporating many unique features. The one piece frame is made from heavy gauge welded steel and is extremely rigid to withstand high blade tensions. The cast iron deep section table features a ground surface and a rack and pinion tilt mechanism with indexing stops for common angles. The heavy gauge alloy rip fence is mounted on a cast alloy bracket which incorporates a fine width adjustment. The fence is clamped with a cam action lever, easily released to allow swift adjustment. Blade guides are all ball bearing with micro adjustment for accurate control. The top guide is mounted on a steel hexagon bar for stiffness and adjusted for height by a small rack and pinion system. A pair of cast iron band wheels, precisely machined and balanced are driven by a multi V belt with a choice of two speeds. The AP1854B has a 750W induction motor, great for cutting all types of wood. Supplied with a 1/2" x 6tpi bandsaw blade.
An optional floor stand is available, featuring adjustable height feet to give a comfortable working height.
Max depth of cut 160mm, max width 250mm
High strength construction wth ground cast iron table
Rack and pinion adjustment of the table tilt and cutting depth
Machine Classification
