Axminster Professional AP200HDG Heavy Duty Grinder - 230V
107670
Special Price £125.98 £104.98 was £169.98 £141.65 Save £44.00 £36.67
36 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Jul
  • Heavy-duty, 200mm bench grinder
  • Solid design and construction, 45mm diameter extraction outlets
  • Adjustable safety shield; 900W, 230V motor
  1. Axminster Professional AP200HDG Heavy Duty Grinder - 230V
Total:
£388.32 £323.60
The AP200HDG grinder combines plenty of power, good design, 200mm diameter wheels and solid construction. The base is 200 x 320mm and has four fixing points. The 900W induction motor runs exceptionally smoothly and provides power for all types of grinding. The guards are very solid and have 45mm diameter outlets at the rear for connection to an extraction system. The tool rests and eye shields are robustly made, the eye shields being fully adjustable to any position. Finally, to finish off a good job the grinder is fitted with a no-volt-release switch. Supplied with aluminium oxide 36-grit coarse stone, 60-grit medium stone. Please note, SIT Wire Brushes not compatible with this grinder.
Note: When a grinder is new or when changing stones it is important to dress the stones to ensure the front face runs true. We recommend using a suitable dresser in order to get the most out of your grinder.
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classifcation
4.20 36
