Axminster Professional AP535SS Scroll Saw - 230V
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Arm assembly tilts, table remains horizontal for greater control
- Fitted with the Pegas blade clamps for easy blade changes
- 535mm throat capacity; 50mm cutting thickness capacity
A high precision machine
A great tabletop machine that cuts via very fine blades allowing for very small, very high precision cuts.
Buy with confidence
Tilting arm
The saw's arm assembly is able to tilt, with pre-set angles at 90°, 45°, 30° and 22.5°. This feature ensures the table is kept flat for easier working. It also allows for greater control and more precision when cutting.
Pégas quick change blade clamps
These blade clamps make changing blades faster and easier; you’ll notice a significant difference to the performance of your scroll saw.
Epoxy coated steel table
The hard-wearing surface allows your work to move smoothly across it. At 345mm x 597mm, its supportive for larger workpieces too.
Variable speed
With between 400-1400 strokes per minute, the variable speed of the scroll saw enables you to cut various materials.
Spring loaded arm
Cut pierced projects with ease and without a fiddly set up process; the scroll saw arm is spring loaded and can be lifted, allowing you to locate the workpiece without bending the blades.
Efficient extraction and air blower
An air blower keeps the cutting line clear; vital when cutting precision work. Dust extraction takes place immediately below the blade via a 63mm outlet ensuring a clean working field.
This 535mm throat scroll saw includes an innovative design, quality construction and comes with some unique features.
The arm assembly tilts up to 45° to the right and 35° left leaving the table horizontal. With your workpiece level, you automatically have greater control and precise cuts are easier to achieve. Visibility is improved and work carried out in a natural position. The saw has a 345mm x 597mm, heavy gauge, epoxy coated plate steel table, giving plenty of support to larger workpieces. Blade changing could not be made easier. No tools required, PEGAS blade clamps are lightweight, reduce vibration and reduce stress on the machine. Changing a blade is a simple matter of operating a quick release lever. When carrying out pierced work, you can raise the upper arm to give yourself more clearance to thread the blade through the hole in the workpiece.
The variable speed control offers 400 to 1,400 strokes per minute. The control knob is conveniently placed within easy reach. Upper and lower blade guards, an air blower and work hold down are all standard. The blade actuating arms are very short, driven by a lever and rod mechanism improving control of the blade and lowering vibration. Dust extraction from immediately beneath the blade is very efficient when connected to a suitable fine dust extractor.
Using unpinned blades offers a vast choice to suit any project, you can even use 150mm lengths of 1/4" bandsaw blade for cutting thicker materials.
Supplied with an assorted pack of Swiss made PEGAS blades.
Axminster Professional 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Professional machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classifcation
Arm Tilt | 35° - 0° - 45° |
Dust Extraction Outlet | 63 mm |
EAN Barcode | 5052511124640 |
Max Depth of Cut @ 90º | 51 mm |
Model | AP535SS |
Motor Power | 320 W |
Nett Weight | 29.5 kg |
Overall L x W x H | 812 mm x 380 mm x 387 mm |
Plug Fitted | UK 3 pin plug |
Rating | Trade/Professional |
Stroke Length | 18 mm |
Strokes per Minute | 400 - 1,500 (var) |
Table Size | 345 mm x 597 mm |
Throat Depth | 535 mm |
Voltage | 230 V |
- Standard Delivery* - Free
