Axminster Professional Bar Clamp Rack
- Organise unruly long clamps, F clamps, sash clamps, parallel jaw clamps etc
- Extra heavy gauge steel up to 25kg load capacity, holds up to 12 clamps
- Pre-drilled for wall mounting; made in the UK
Axminster Professional Parallel Jaw Clamp 300 x 80mmSpecial Price £12.52 £10.43 was £18.68 £15.57 Save £6.16 £5.13
Axminster Professional HD Parallel Jaw Clamp Pivot 600 x 95mmSpecial Price £30.28 £25.23 was £45.18 £37.65 Save £14.90 £12.42
Axminster Professional Ductile Cast F Clamp 100 x 50mmSpecial Price £7.62 £6.35 was £11.38 £9.48 Save £3.76 £3.13
See the entire range
This rack will deal with your storage problem in the best possible way. It will safely store your F clamps, sash clamps and parallel jaw clamps.
The storage slots are 12mm wide and the capacity is up to 12 clamps or 25kg. Made of 2mm thick steel with a painted finish they are unlikely to bend under load or rust over time. Each rack is 600mm long and pre-drilled for fixing on a wall.
This is an ideal companion to the Axminster Professional G clamp rack. Tidy up, gain more workshop space and say goodbye to that heap of clamps in the corner.
Made in the UK.
EAN Barcode | 5052511100705 |
Model | E699 |
Overall L x W x H | 600 mm x 67 mm x 98 mm |
- Standard Delivery* - £1.99
