Earn extra with DOUBLE Points on all purchases!
Axminster Professional Panel Carrier 0-65mm (Pkt 2)
- Indispensable when dealing with cumbersome sheet material
- Safe and convenient way to carry panels and boards.
- Spring loaded, self adjusting, non-slip jaws
See the entire range
The Axminster Professional Panel Carrier helps you move large unwieldy board material safely and with ease. The spring-loaded eccentric cam jaws are self-adjusting. A high-friction covering guarantees a firm non-slip grip across the full clamping range.
The self-adjusting jaws make it quick and simple to place the carrier in the most convenient position on the board. The design makes it possible to pull panels out from a panel rack using the front edge. The Axminster Professional Panel Carrier lets you move cumbersome sheet material such as wood, chipboard, OSB board, plasterboard, non-lubricated metal etc. comfortably and safely.
Capacity 0 to 65mm
EAN Barcode | 9120081540071 |
- Standard Delivery* - Free
