Axminster Workshop 102mm to 100mm 360deg Dust Extraction Swivel
108795
108795
From £13.28 £11.07
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Jul
  • 15° swivelling design rotates 360°
  • Helps prevent hose kinking or pulling off the extractor
  • 102mm bore inlet for extractor, 100mm outlet for hose
  • 50mm long ports for secure for secure connection
  • Moulded from strong and durable ABS
  1. Axminster Workshop 102mm to 100mm 360deg Dust Extraction Swivel
Total:
£101.12 £84.27
This double-ended swivel elbow is a great way to attach a flexible hose to a machine. It offers excellent articulation to a dust hose connection. In effect it is a 15° ball-joint, able to rotate a full 360°. It helps prevent your hose from kinking, binding or pulling off the dust extractor. One inlet has an internal bore of 102mm, designed to fit over a 100mm inlet/outlet or another ABS extractor fitting. The second inlet has an outer diameter of 100mm to take the flexible extractor hose and hose clamp. Both inlets/outlets are 50mm long to ensure a secure connection.
Moulded from durable ABS, the overall length is 230mm, width 165mm.
