Axminster Workshop AW1400B Bandsaw Blade & Mitre Fence Kit
720879
720879
From ÂŁ29.98 ÂŁ24.98
  5. Half Star
9 Reviews
In Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery tomorrow, Friday 28th Mar
  • Upgrade package for the AW1400B Bandsaw
  • Three essential accessories to enhance your bandsaw's performance
  • Cut perfect mitres to tight curves and everything in between
  • Mitre fence makes cutting mitre angles simple and easy
  • Comes with two Axcaliber carbon steel bandsaw blades
  • Axcaliber blades consistently cut straighter and have harder, longer-lasting teeth
  1. Axminster Workshop AW1400B Bandsaw Blade & Mitre Fence Kit
Total:
ÂŁ289.92 ÂŁ241.60
Upgrade your woodworking experience with the Axminster Workshop AW1400B Bandsaw Blade and Mitre Fence Package. This package includes three essential accessories that will enhance your bandsaw’s performance and versatility. The perfect package for getting the most from your Axminster Workshop bandsaw; from cutting perfect mitres to tight curves and everything in between.
Axminster Workshop Mitre Fence
Nicely made in cast alloy, with clear markings and slots to fasten a sacrificial fence onto. There is a large handle to give a firm grip, plus a small magnifier lens to view the angle markers more easily. This is a very useful addition to the bandsaw, being accurate and smooth running in a 13 x 9 x 9mm table T-slot.
Axcaliber Bandsaw Blades
Axcaliber bandsaw blades, crafted in Axminster using state-of-the-art CNC machining and high carbon steel sourced from the UK, consistently deliver precise and clean cuts. Over the years, Axcaliber has become the preferred blade brand for many users. Rigorous quality inspections are conducted at every manufacturing stage, and the weld is annealed to eliminate brittleness and risk of fatigue. This makes Axcaliber one of the few brands globally that guarantees the weld on their blades. The superior manufacturing quality and materials result in a blade that cuts straighter, possesses harder and longer-lasting teeth, giving a superior finish to the workpiece. The Axminster Workshop AW1400B Bandsaw Blade and Mitre Fence Package includes the following Axcaliber blades:
Axcaliber High Carbon Bandsaw Blade 1,400mm (55 1/8") x 9.5mm 4 tpi - good for general purpose use with a degree of cutting across the grain and with the grain. A reasonable finish can be achieved with slower feed rates and good tension.
Axcaliber High Carbon Bandsaw Blade 1,400mm (55 1/8") x 6.3mm 6 tpi - the ideal general purpose blade suitable for cross cutting.
4.40 9
