Axminster Workshop AW1400B Bandsaw - 230V
Unused returns, open-box items, or cosmetically imperfect products, fully inspected and offered at a discount: Axminster Workshop AW1400B Bandsaw - 230V *Outlet*
Only left in stock
- 80mm depth of cut - 200mm width of cut
- Compact machine perfect for hobbies and crafts
- Rigid, quick locking rip fence, doors fitted with safety switches
Perfect for small to medium woodworking projects
The Axminster Workshop AW1400B Bandsaw weighs in at 20kg, making it the smallest bandsaw in our Axminster Workshop range, and is packed with features not normally found on a saw of this size.
Buy with confidence
Why this bandsaw deserves to be in your workshop...
A space saving solution
The small, compact size allows you to save valuable floor space and can be easily stored or moved to one side when not in use.
Bearing Guides
New and improved top and bottom bearing guided blade system provides improved accuracy and easy set up. The top guide has a height adjustment, allowing max 80mm depth of cut.
Increased cutting accuracy
Similar to the larger bandsaws in the Axminster Workshop range is the wide, curved steel chassis. This design gives you excellent tension on the blade to increase the cutting accuracy!
Easy access
The keyless opening on the door means you can access inside your bandsaw with a simple twist of the knob.
Stable and robust
The bandsaw’s table is finely ground, solid cast iron and tilts from 1 to 45 degrees. This enables your work to glide effortlessly through the machine, allowing you to take on larger projects with peace of mind.
How to get the best out of your AW1400B
Learn how to set it up for accurate cuts
Our experts show you everything you need to know, right through to making your first cut!
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
Axminster 63mm Extraction Hose with Clips - 3mSpecial Price £20.98 £17.48 was £29.88 £24.90 Save £8.90 £7.42
The Axminster Workshop AW1400B bench mounted bandsaw is designed for the small workshop and easily moved when not in use.
It features a strong welded steel chassis with a cast iron table. It will take blades from 4.8 to 9.5mm wide. Bearing blade guides and thrust bearing provide maximum blade control for improved accuracy over similar entry level bandsaws. The top guide blade has a rack and pinion height adjustment, giving a maximum of 80mm depth of cut.
It has a direct drive motor and balanced cast alloy wheels. The top wheel is mounted in a welded steel sub frame with blade tensioning and tracking controls conveniently close.
A single dust outlet port provides efficient dust removal when connected to a suitable vacuum extractor, which must be recommended for increased cutting performance.
The machine is supplied with a 6mm x 6tpi general purpose blade made from UK manufactured stock. A selection of different blades are available to suit many jobs.
An optional mitre fence is available to fit this bandsaw (sold separately).
This is a superb small bandsaw for a hobby or craft workshop or as an additional machine for smaller work.
Please note, if you require an EU plug, please ensure you purchase 113504
Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed and intended for those who require equipment for more regular, but not continuous, operation. They must be maintained and serviced in line with our schedule; otherwise guarantee may be void.
Learn more| Bandsaw Blade Length | 1,400 mm (55") |
| Bandsaw Wheel Diameter | 200 mm |
| Blade Speed | 800 m/min |
| Blade Width Min\Max | 4.8 mm to 9.5 mm |
| Dust Extraction Outlet | 40 mm |
| EAN Barcode | 5052511124886 |
| Max Cutting Height | 80 mm |
| Max Width of Cut | 200 mm |
| Max Width of Cut with Fence | 102 mm |
| Min Extraction Airflow Required | 200 m³/hr |
| Model | AW1400B |
| Nett Weight | 20 kg |
| Overall L x W x H | 450 mm x 430 mm x 700 mm |
| Power | 250 W |
| Rating | Regular Use |
| Sound Power Level LwA [Uncertainty K] | 97 dB(A) [3.0 dB] |
| Sound Pressure Level LpA [Uncertainty K] | 83.5 dB(A) [3.0 dB] |
| T Slot Size | 13 mm x 9mm |
| Table Height | 290 mm |
| Table Height on Stand | N/A |
| Table Size | 300 mm x 300 mm |
| Table Tilt | 0° - 45° |
| Voltage | 230 V |
- Standard Delivery* - Free
