Axminster Workshop AW1950B Bandsaw Blade & Mitre Fence Kit
- Upgrade package for the AW1950B Bandsaw
- Three essential accessories to enhance your bandsaw's performance
- Cut perfect mitres to tight curves and everything in between
- Mitre fence makes cutting mitres simple and easy
- Comes with two Axcaliber Ground Tooth Blades
- Blade's unique diamond ground tooth gives an exceptionally clean cut
- Cut consistently straighter with teeth that last up to 30% longer
Upgrade your woodworking experience with the Axminster Workshop AW1950B Bandsaw Blade and Mitre Fence Package. This package includes three essential accessories that will enhance your bandsaw’s performance and versatility. The ideal package for getting the most from your Axminster Workshop bandsaw; from cutting perfect mitres to tight curves and everything in between.
Axminster Workshop Mitre Fence for 19mm Slots
This mitre fence has a solid steel bar 19mm x 9.5mm (3/4" x 3/8") and 320mm long. It will fit onto any machine or router table with a similar size groove. Installation is simple and you can make the bar a perfect fit in your mitre slot. The bar has a removable locking washer at one end for T-slot grooves. If you have a plain slot, just unscrew the washer. Along the side of the bar, three adjustable grub screws, allow you to remove any play between the bar and groove for smooth, accurate operation. Once set up in your machine’s slot, it will allow you to cut accurate mitres every time.
This quadrant is 5mm anodised aluminium plate featuring positive stops at 0°, 22.5°, 30°, 45°, 60°, 67.5° and 90°. A spring-loaded plunger locks into the indents for rapid adjustment to common angles. The pointer and degree scale allows you to set the quadrant to any other angle between 0° and 90° left and right as required.
Axcaliber Bandsaw Blades
Axcaliber bandsaw blades, crafted in Axminster using state-of-the-art CNC machining and high carbon steel sourced from the UK, consistently deliver precise and clean cuts. Over the years, Axcaliber has become the preferred blade brand for many users. Rigorous quality inspections are conducted at every manufacturing stage, and the weld is annealed to eliminate brittleness and risk of fatigue. This makes Axcaliber one of the few brands globally that guarantees the weld on their blades. The superior manufacturing quality and materials result in a blade that cuts straighter, possesses harder and longer-lasting teeth, giving a superior finish to the workpiece. The Axminster Workshop AW1950B Bandsaw Blade and Mitre Fence Package includes the following Axcaliber Ground Tooth blades:
Axcaliber Ground Tooth Bandsaw Blade 1,950mm (77") x 12.7mm 3 tpi - used for deep cutting especially rip cuts.This blade will leave a rough sawn finish although slow feed rate and high tension will improve the finish of the cut.
Axcaliber Ground Tooth Bandsaw Blade 1,950mm (77") x 6.3mm 6 tpi - the ideal general purpose blade suitable for cross cutting.
The diamond ground teeth are so unbelievably sharp (and stay sharp for at least 30% longer) that the blades work extremely well in all materials giving an exceptionally high quality finish and clean cut.
