Spread the cost of orders up to £15,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £15,000.
When you get to the iwocaPay checkout you'll see two choices:
Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
Vacuum pressing is the most effective way to clamp veneering work and light weight laminations, providing an even and massive clamping pressure over the whole surface. By extracting the air from the vacuum bag and creating a vacuum, the full weight of atmospheric pressure bears down on the contents of the bag exerting an evenly distributed pressure of around 8.5 tons per m². These units use a top quality Becker dry running vane vacuum pump giving between 4 and 25m³ per hour developing 85% vacuum. A built in vacuum gauge gives a visual indication of performance whilst a heavy duty foot switch gives convenient control. An extra large capacity 2,500 x 1,300mm heavy duty 300 micron seamless vacuum bag is supplied as standard and will accommodate almost any project. The 16 and 25m³ units will run up to 4 bags simultaneously. A convenient storage box houses the pump unit. If you are laminating with a vacuum press it is only necessary to provide a one piece former as the vacuum bag will provide an even pressure as it moulds the timber into the shape of the former.
This product is classified as a Dropship product. Dropship products are usually
readily available and despatched directly from the manufacturer using the best delivery service
available. Despatch times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact
customer services
for more information.
