Woodworking Wisdom
UJK Universal Dovetail Jig
With strong associations of quality and craft, and highly prized worldwide, British Made products offer peace of mind that you’re investing in the best! With this in mind, we're delighted to showcase the UJK Universal Dovetail Jig, available to buy online, in store or over the phone.
UJK Universal Dovetail Jig - Made In Britain
1 jig, 6 joints
Straight out of the box, the UJK Universal Dovetail Jig gives you the possibility of producing six different joints, with unrivalled accuracy! Plus, it's simple to use and easy to set up. View the jig and buy yours now.
Six joints straight out of the box
Half Blind Dovetail
Half blind dovetails
Used primarily for drawer box construction, half blind dovetails show the pins and tails on one side of the joint, while remaining completely invisible on the other. This makes them ideal for fastening drawer fronts to drawer sides.
Sliding Dovetail
Sliding dovetails
Frequently used in case work to connect shelves to side walls or between shelves in drawer dividers, sliding dovetails are deceptively simple joints to make using this jig.
Through Dovetail
Through dovetails
As one of the strongest joints available, the through dovetail joint has many benefits. These include being aesthetically pleasing thanks to its interlocking capabilities and resistance to being pulled apart. Furthermore, it offers a large gluing area, however the joint will also hold together even without glue!
Box/Finger
Box/Finger joints
Ideal for making boxes and other solid cube shapes such as chests and carcases, precise comb or finger joints offer castellations with a very long glue line.
Groove/Housing
Groove/housing joints
Useful for adding partitions into cabinets and bookcases, a groove/housing joint is a strong and reliable joint that's simple to make. A trench is cut into which the end of another component is inserted.
Corner Dovetail Rebates
Corner dovetail rebates
Simple to construct, corner dovetail rebates enable mating parts to align easily and accurately. Furthermore, they create a larger gluing surface which provides a greater load-bearing capability than standard butt joints.
UJK Universal Dovetail Jig Fine Pitch Comb
UJK are proud to launch the ultimate companion
to the Universal Dovetail Jig
The British Made UJK Universal Dovetail Jig Fine Pitch Comb! A worthwhile addition to your set up, allowing you to create two more joints on the UJK Universal Dovetail Jig, a fine 6mm half-blind dovetail or box joint, perfect for small, intricate projects.
Why buy the UJK Universal Dovetail Jig?
Do more, work less, get better results. Learn more!
Made in the UK
The jig is made and developed at UJK's state-of-the art manufacturing facility in Britain. Straight out of the box it gives you the possibility of producing six different joints, with unrivalled accuracy. With "British Made" status, UJK takes particular pride in the manufacture of their own products and this couldn't be more true with the UJK Universal Dovetail Jig.
From concept, design, material selection and sourcing through to prototype development, testing, quality control and finally, the production of the jig itself, when we say 'British Made' we are able to truly mean it. Please note: the knobs and cutters are not made in the UK.
High quality materials
The base of the jig is robustly made from heavy gauge steel. Other parts precisely CNC machined; a combination of accuracy and strength. The super hard anodised finish on the finger templates ensure long term accuracy. The jig features a stabiliser bar located in front of the hard anodised comb. This provides a much greater surface area to support your router’s base. It is also where that the quick fit magnetic extraction nozzle fits.
Stabiliser bar Stabiliser bar located in front of the comb supports your router's base
Simple set up and use
For convenience, the UJK Universal Dovetail Jig is straightforward to set up and use. An 11mm offset at each end of the template greatly speeds up initial marking. Finally, fast cam action clamps, hold your workpieces quickly and securely.
Fantastic dust extraction
The UJK Universal Dovetail Jig incorporates an impressive dust extraction outlet. Held in place by a strong magnetic strip, the outlet is easily detached when loading workpieces in your jig.
Magnetic dust extraction Held in place by a strong magnetic strip, the greatly improved dust extraction outlet is easily detached when loading workpieces in your jig
Compatible with a range of routers
The UJK Universal Dovetail Jig lets you achieve perfect joints, every time. Very simple to use compared to the more complex jigs and at a fraction of the price, the new dovetail jig from UJK can be used with any router that will take 1/4″, 8mm or 1/2″ shank cutters.
What's included?
The UJK Universal Dovetail Jig comes with:
  • Three 1/4" shank Axcaliber precision ground TCT router cutters; a matched pair for dovetailing (7° dovetail and straight) plus a 12.5mm straight cutter
  • Two American style threaded guide bushes
  • Router support bar
  • Magnetic extraction nozzle
  • Setting gauge
  • 2 combs
  • 3 point clamping system
  • Full instructions
Important info...
Material capacity: 300mm width, 6–28mm dovetail thickness. Don't forget, an additional UJK guide bush adaptor to suit your router should be purchased separately.
See guide bushes
Discover more...
If you enjoyed reading this blog, why not check out more articles on UJK products?
Firstly, drilling straight and accurate holes freehand isn’t easy. If you want real accuracy, many people turn to a pillar drill but not everyone has the room for a floor standing or even a bench mounted model. To overcome this problem the improved UJK Drill Guide with 10mm chuck has been designed to be an accurate, portable pillar drill. Read our informative guide to discover the key features that will help you drill the perfect hole.
Next, if you want strong and hidden joints, UJK Pocket Hole Jigs offer a perfect solution. Read our guide to learn more about some of the advantages of using pocket hole jigs for your woodworking projects.
See the full UJK range
UJK range
A unique Axminster brand with a focus on British manufacturing
Get connected!
Follow us on Instagram and Facebook to stay up to date on all the latest from Axminster Tools. Connect with us using #UJK to @AxminsterTools.
Leave a comment
