Bosch 4+1 Multi-Tool Blade Renovation Set (Starlock)
- Essential set for renovation, remodelling or refitting
- Perfect for plumbers, electricians and tilers
- Contains 4 blades, sanding pad and abrasive
Customers Also Bought
This is an essential set for any multi-tool owner embarking on a renovation project, kitchen fitting or bathroom remodelling. This is a most useful piece of kit to have on board for plumbers, electricians and tilers. The set contains 4 blades and a delta sanding pad with 3 sheets of delta abrasive. The blades and pad will fit machines that take Starlock, Starlock Plus and Starlock Max accessories.
The blades are as follows;
1 x AIZ 32 APB bi-metal blade is for exact flush and deep plunge cuts in wood, metal and plastics. It cuts precisely thanks to a slightly curved cutting edge. Good for nails, copper pipe as well as timber.
1 x ACZ 85 EC is a segmented blade for cutting wood and similar materials this is a high carbon steel (HCS) blade. It will cut flush to a surface as well as into an edge or corner.
1 x ACZ 70 RT5 is for cleaning grout in narrow seams between small and large tiles with no damage to adjoining tiles, as well as easy and precise cutting in fibreglass and epoxy parts. The edge is tungsten carbide abrasive grit for long life.
1 x ATZ 52 SC is a high carbon steel scraper blade for removing adhesive, paint and other residues from a surface.
All packed in a tough carry case.
- Fits multi-tools able to take Starlock, Starlock Plus, Starlock Max
- All packed in a tough carry case
