Dremel Tile Cutting Bit (562)
108040
From £11.38 £9.48
2 Reviews
Delivery
£4 Standard Delivery*. Free delivery over £50.
Estimated stock arrival in 5 weeks.
  • Designed for cutting and shaping ceramic wall tiles
  • Cut and trim tiles around pipes and fittings
  • Shank diameter 3.2mm, working length 20mm
  1. Dremel Tile Cutting Bit (562)
Total:
£52.32 £43.60
The Dremel 562 spiral cutting bit is designed for shaping and cutting ceramic wall tiles (not suitable for use on porcelain floor tiles). Use the 562 cutter to enlarge holes or help cut and fit tiles around pipes and fittings. It can be used on plastic, fibreglass, aluminium and similar materials.
Shank Diameter - 3.2mm
Working Diameter - 3.2mm
Working Length - 20mm
Maximum speed - 35,000 rpm
5.00 2
