Easy Wood Tools Ci0 Carbide Cutter - Round
- Fits the Full-Size Easy Finisher and Pro Easy Finisher.
- 16mm diameter, solid carbide
- Optimum grade of carbide, long lasting cutting edge
- Proprietary grinding for the sharpest edge possible
- Precision ground finish
- Easy Wood Tools tips are 100% made in the USA
The Ci0 round solid carbide tip is 16mm diameter. It fits the Full-Size Easy Finisher and Pro Easy Finisher
The standard carbide tips provide a neutral rake, which is the angle of a cutter relative to its cutting surface minimising the risk of catches and blowouts. These cutters start sharp and stay sharper far, far longer.
When one side of the cutter eventually dulls, simply rotate to a fresh cutting edge and continue turning. When all edges are used, simply replace the cutter. More time for turning and zero time spent sharpening.
Easy Wood Tools® is the only turning company that manufactures its own carbide. All the tips are made in the Easy Tools manufacturing plant in Illinois USA. Easy Tools has complete control over the process and the quality. Their proprietary formula is the sharpest, hardest and longest-lasting in the industry.
