The GKF 600 palm router from Bosch comes with built-in versatility. It's hugely useful for the trimming laminates, edge moulding, mortising hinges and any other work that benefits from a powerful but light and easy to control router. The 600W motor means that this palm router is almost as powerful as many 1/4" routers and more powerful than many dedicated laminate trimmers. This versatile router, with its neat and compact design (overall size 94 x 94 x 190mm high) is easy to handle and control and is especially suitable for confined areas.
The height adjustment is really easy to set, a lock lever releases the motor from the base allowing quick coarse adjustment; the micro fine adjuster dial can then be used to set height accurately. The base allows a clear view of the cutter so you can see exactly where you are cutting. The spindle lock makes changing cutters easy. Fitted with a 1/4" collet, the 600W motor runs at 33,000rpm.
The GKF 600 comes with a Parallel guide fence, a Bearing guided fence, 1/4" collet and collet nut, 17mm spanner and a storage/carry case.
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
