Festool CSC SYS50 EBI-Basic Cordless Table Saw Set 18V (Body Only)
720847
From £2,199.98 £1,833.32
2 Reviews
Delivery
Free Standard Delivery*.
Estimated stock arrival in 8 weeks.
  • A table saw and trolley/leg stand for easy transport
  • A cordless saw with mains power performance
  • Digital display for both blade height and blade tilt
  • Set the depth of cut to within 0.1mm
  • Set blade angle to within 0.1°
  • Low maintenance, powerful EC-TEC motor
  • Systainer lid features storage for the fences etc
  • Cross cut width at 90° - 450mm
  • Parallel rip cut width - 280mm
  • Cutting height at 0° - 0 to 48mm
  • Blade Tilt -10° to +47°
  • Show More
A table saw in Systainer format
Serious sawing, on the go.
Particularly precise
Removes the guesswork. Produces maximum precision down to accuracies within a tenth of a millimetre. With 100% repeatable accuracy, you’ll never miss the mark.
Optimal technology
Keep it simple. Set your desired sawing height and angle at the press of a button, via the digital display and dial. This adjusts the saw blade automatically.
Exceptional capacity
Simply impressive, offering a scope of cuts. From parallel cuts of up to 280 mm, a cross-cut width of up to 450 mm and angled cuts of -2° to 47.
Unparalleled power
Power isn’t compromised in this cordless machine. Even rip cuts in solid wood, the 2x 18V dual battery system with the powerful brushless EC-TEC motor will impress you. Takes Festool 4.0Ah and 5.0Ah Batteries.
Undeniably compact and mobile
So compact it fits into a Systainer, you don’t get more mobile than this. Achieve workshop quality sawing, on the construction site. Simple.
Fast changes
Efficient working. Change the saw blade quickly, without any complications.
Efficient storage
Keep everything to hand. Saw blades, a space wedge and dust collection bag are all securely stored in the lid of the Systainer.
Seamlessly compatible
Simply Festool. Combine your cordless saw with a cordless extractor, it just makes sense.
  1. Festool CSC SYS50 EBI-Basic Cordless Table Saw Set 18V (Body Only)
Total:
£3,449.62 £2,874.68
The CSC SYS 50 cordless table saw and the UG CSC SYS Underframe is the perfect combination, offering mobility, stability and great functionality. The CSC SYS 50 with its Systainer format along with the large wheels on the UG CSC SYS makes transportation a breeze.
When you arrive on site, the UG CSC quickly turns into a dual height leg stand; with the legs deployed, the working height with the saw is a comfortable 900mm. Alternatively, in cases where working closer to the ground is preferable, such as floor laying, with the legs folded, the working height is 245mm.
The CSC SYS 50 Saw is fully compatible with the entire Festool Systainer system. Power comes from two 18V batteries (from 4.0Ah upwards) in combination with a brushless EC-TEC motor, resulting in performance more than comparable to a mains-powered machine. NOTE: this is a body only machine supplied without batteries or charger.
The outstanding feature has to be the digital display for both blade height and blade tilt. Select the function, then turn the knob to set the depth of cut to within 0.1mm or the blade angle to within 0.1°. Reproducing cuts couldn’t be more accurate, the digital display ensures precise results. Four saw blade positions can be saved and selected via the digital display. The height and angle are electrically adjusted at the press of a button.
The brushless EC-TEC motor with high speeds of 6,800 rpm guarantees fast sawing progress. The CSC SYS 50 allows you to make parallel rip cuts of up to 280mm wide and cross-cut widths of up to 450mm. The maximum depth of cut is 48mm and the blade tilt; from -10° to 47°.
On the left hand side the super smooth sliding table and mitre crosscut fence allow cutting up to 450mm in front of the blade and mitre angles from -70° to +70°. On the right hand side a fold down table extension and rip fence allow cuts of up to 280mm wide. The rip fence locks front and back with a single clamping lever.
Supplied with 42 tooth TCT saw blade and chip collection bag. Alternatively, it can be connected to a suitable vacuum dust extractor.
Table height 228mm
Cross cut width at 45° - 340mm
Cross cut width at 70° - 140mm
Cutting height at 45° - 0 to 34mm
Cutting height at 47° - 0 to 33mm
Cutting height at ‑2° - 0 to 48mm
Cutting height at ‑10° - 21 to 32mm
Benefits
  • Includes 36 month machine guarantee
  • Full repair, free of charge
  • Replaced in the event of theft
  • Original parts guaranteed
  • 14 day money back
5.00 2
