Festool MINI Systainer T-LOC with Transparent Lid
- Convenient and organised Mini Systainer with transparent lid
- Transparent lid allows you to view contents without opening
- Robust ABS construction with moulded-in ribs for strength
- For small parts, consumables or hand tools
- Contents stored safely and securely
- Protects against dust, dirt, splashes and impacts
- Mini T-LOC Systainers stack and lock together
- Overall size 265 x 171 x 70 mm
The Mini Systainer case might be a smaller Festool T-LOC case, but that doesn't make it any less useful. This version has a transparent lid allowing you to view the contents without opening the case.
Mini it maybe in name, but it is certainly big when it comes to usefulness. The size makes it ideal for small parts, consumable items or hand tools. Screwdrivers, pliers etc fit perfectly. The design protects the contents against water splashes, dust, dirt and impacts.
The T-LOC latch allows you to stack and lock multiple cases together, for easy carrying. You can also open individual cases while in the stack.
The Mini Systainer is 265mm wide x 171mm deep front to back and 70mm high.
N.B. Cannot be connected to T-LOC SYS 1, SYS 2, SYS 3, SYS 4, SYS 5 or SORTAINER.
