Festool T-LOC Systainer3 337 Storage Case (SYS3M)
- H 337mm x L 396mm x W 296mm
- Durable and reliable with excellent functionality
- Cases lock together using the T-LOC central controller
- Be better organised, with greater protection and easier mobility
- Fully compatible with all previous Systainer generations
- Front pull handle design for the Bott system
- Systainer³ is a complete, highly practical storage and transport system
The latest generation of Systainer³ cases enable you to be better organised, more mobile and work with greater efficiency. Systainer³is a complete and highly practical storage/transport system. Developed in conjunction with TANOS and bott; Systainer³ is the perfect answer to safe storage and easy transportation. Precision made for durability and reliability these cases are of the highest quality. They offer simple handling, high functionality and robustness. Be it in the workshop, on site or part of a mobile system in a vehicle, these cases provide the solution.
The cases lock together using the T-LOC central controller, they close, open and connect using a single movement. Systainer³ cases connect with one another and are fully compatible with all previous Systainer generations, mobile dust extractors and many other system accessories.
The large Systainer³ case features a front pull handle design for the Bott system making it ideal for transporting in vehicles. This also makes it easy to remove the Systainer³ from a shelf system. As the case has a greater depth than height, the case has a pull-out aid and is best carried using the lid handle.
