Festool T18+3 HPC 4.0 I-SET Drill Driver 18V (4.0Ah)
- Ultra compact, well balanced, high precision 18V drill driver
- EC-TEC® brushless, wear resistant motor, for extended runtimes
- Electronic brake and electronic torque for complete control and screwdriving precision
Customers Also Bought
The T 18+3 combines the 18V 4.0 HPC-ASI batteries with an advanced brushless EC-TEC® motor and a patented compact gear mechanism. This combination results in higher efficiency, better reliability and a longer service life. The EC-TEC® brushless motor delivers more power and longer runtimes. The electronically controlled torque significantly reduces wear and tear on the motor and bearings. It produces the same torque regardless of the speed. It enables you to switch back and forth between drilling and screwdriving without losing your torque setting. An LED illuminates the target area when you squeeze the drill's trigger.
The T 18+3 is compact, lightweight and well balanced. The front end features Festool’s FastFix interface and is compatible with all FastFix attachments and the CENTROTEC® rapid tool-change system. This alone makes the T 18+3 one of the most versatile cordless drill drivers available. Festool AIRSTREAM technology offers super fast charge times without compromising battery capacity or runtimes.
The AIRSTREAM batteries are compatible with all Festool 18V cordless tools.
T 18 SET is supplied with 2 x BP 18 Li 4.0 HPC-ASI battery pack, rapid charger TCL 6, CENTROTEC tool chuck, CENTROTEC bit holder, FastFix Keyless chuck 13mm, bit PZ 2, BKS SYS3 D5 PZ TX 100 CE bit cassette, FastFix angle attachment, FastFix eccentric attachment, belt clip and a SYSTAINER SYS3 DF M 187 T-Loc case with lid assortment.
Registering the drill for an extended warranty includes a 3-year warranty on the batteries.
Note: Charger fitted with UK 3-pin plug.
- Switch from drill to screwdriver mode without torque change
- Motor and battery protection, charge indicator
- Supplied with 2 x BP 18 Li 4.0 HPC-ASI battery pack, rapid charger TCL 6, CENTROTEC tool chuck, CENTROTEC bit holder, FastFix keyless chuck 13 mm, bit PZ 2, BKS SYS3 D5 PZ TX 100 CE bit cassette, FastFix angle attachment, FastFix eccentric attachment, belt clip and a SYSTAINER SYS3 DF M187 T-LOC case with lid assortment.
