FISCH Auger Bits 1/4" Hex Shank
AX1034438
AX1034438
- 1/4" hex shanks fit quick change chucks and keyless chucks
- 235mm long, ground from one piece for strength
- Excellent waste clearance, quick cutting, made in Austria
Show more
Show less
235 mm long auger bits of the highest quality, made by FISCH in Austria. They feature 1/4" hex shanks enabling you to use them in a 1/4" hex quick change chuck or for a non slip grip in a keyless drill chuck. Suitable for soft and hard wood. A deep gullet rapidly clears the waste and the threaded tip helps pull the auger into the timber for a fast, clean cut. The auger bit is ground out of one piece of steel to ensure precision with high accuracy to give a long working life. Shanks tempered to DIN 3126-E6,3.
Drill Bit Length | 235 mm |
